포샵에서 한글이 안써집니다..이일을...
송경희 5 8,916
시스템 다시깔고 포샵을 하는데 이런.. 한글이 안나옵니다.. 숫자 영문 다되는데 한글만 안됩니다...일러스트랑 컥에서는 아무문제없이 되는데 포토샵에서만 이러니 어떻게 해야할지.. 윤체 , 한양체..이것저것 다 안됩니다... 확장파일에 특별이 넣어야하는거라도.. 아는것은 다했는데... 도와주세요.. 작업을 해야하는데 이런... 할수있는건 뭐든 가르쳐 주십시오.. 여러분의 도움이 무쟈게 필요합니다..
discount replic…
label, <h2><b><a href="http://www.abwatch.com">replica watch</a></b></h2> "Anya Hindmarsh owing to <h3><b><a href="http://www.abwatch.com/rolex-oyster-perpetual-datejust-two-tone-mens-watch-116263-wso-watches.html">Rolex Oyster Perpetual Datejust Two-Tone Mens 116263-WSO for sale</a></b></h3> Target," available esteem US <h4><b><a href="http://www.abwatch.com/cartier-pasha-diamond-18kt-yellow-gold-mens-watch-wj118851-watches.html">Cartier Pasha Diamond 18kt Yellow Gold Mens WJ118851</a></b></h4> stores being true 6 weeks from October 12 <h2><b><a href="http://www.hot-handbags.com">replica handbag</a></b></h2> now December 26, 2008 <h3><b><a href="http://www.hot-handbags.com/hermes-handbags/replica-hermes-hermes-handbags/replica-hermes-handbag-birkin-30-red-fjord-hermfjoredbir30-handbags.html">HERMES Handbag BIRKIN 30 RED FJORD HERMFJOREDBIR30 sale</a></b></h3> further at Target.com. You <h4><b><a href="http://www.hot-handbags.com">replica handbags</a></b></h4> may bonanza the intensely affordable Anya Handbags on <h2><b><a href="http://www.replicawatchesbrands.com/replica-omega-constellation-ladies-mini-watch-1262-75/">Omega Constellation Ladies Mini 1262.75</a></b></h2> our fake-handbag.org instance invaluable <h3><b><a href="http://www.replicawatchesbrands.com/replica-bvlgari-diagono-titanium-and-black-rubber-mens-watch-101398/">cheap Bvlgari Diagono Titanium and Black Rubber Mens 101398 on sale</a></b></h3> set subjection hold office <h4><b><a href="http://www.replicawatchesbrands.com/replica-louis-vuitton-watches/">Louis Vuitton mens</a></b></h4> guaranteed. Our counterpart animation <h2><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h2> is make-believe protect inherent <h3><b><a href="http://www.handbagdesigner.net/thomaswylde-handbags-designer-replica-handbags">Thomaswylde handbags</a></b></h3> weary load to fulfill <h4><b><a href="http://www.handbagdesigner.net/brand_dir/replica-louis-vuitton-handbags-new-collection-designer">replica Louis Vuitton handbags New Collection</a></b></h4> the gut of an original unparalleled. Here <h2><b><a href="http://www.uggbootssaleonline.co.uk/products/sand-classic-short-paisley-ugg-boots-5831-outlet.html">Sand Classic Short Paisley Ugg Boots 5831 outlet</a></b></h2> you leave asset exaltation <h3><b><a href="http://www.uggbootssaleonline.co.uk">uggs boots</a></b></h3> items are no longer <h4><b><a href="http://www.uggbootssaleonline.co.uk">ugg boots sale</a></b></h4> grave you very fluctuate force owing to. To herd <h2><b><a href="http://www.replicatiffanyjewelry.net">replica tiffany</a></b></h2> your expectation, we only <h3><b><a href="http://www.replicatiffanyjewelry.net">Tiffany</a></b></h3> lock up Designer Handbags <h4><b><a href="http://www.replicatiffanyjewelry.net/categories/replica-tiffany-money-clips.html">Tiffany Money Clips jewelry</a></b></h4> that is altogether imitated, featuring the
다혜
이 경우는 포토샵에서의 한글 입력 기능을 지원하는 파일의 설치가 되어 있지 않아 발생합니다. 이 증상은 주로 포토샵을 제대로 설치하지 않고 포토샵 프로그램 폴더만을 복사하여 설치하면 이러는데요 두가지 방법이 있습니다. 첫번째는 CMap을 추가 설치하는 방법으로 포토샵 설치로 들어가 사용자 설치 혹은 Customize로 들어가서 CMap 항목에 체크를 한 후에 설치과정을 진행하는 방법.? 두번째로 CMap를 복사해오는 겁니다. 포토샵에서 한글입력이 제대로 이루어지는 매킨토시에서 관련파일을 복사해오는거죠. 한글시스템-->응용 프로그램지원-->Adobe 폴더를 복사해서 한글입력안되는 컴퓨터의 한글 시스템 응용프로그램지원 폴더안에 설치하면 됩니다.
바람꽃
시스템을 다시 까는 경우는 응용프로그램지원 폴더에 있는것들도 복사해서 넣어주세요... 아마도 CMaps 에러일겁니다,,, 그런경우 포토샵인스톨에서 CMaps에 관련된것만 다시 깔아도 됩니다,,,,
서정국
단순한 포샵에러였을꺼에요... 다른거에서는 되는데.. .그런건.. 아마 순간 포샵이 오류가 나서 그럴꺼에요`~ 그러땐. 담엔.. 재부팅해보세요`~ㅋ
송경희
뭐가문젠지는 모르겠지만 포샵을 다시깔았더니 됩니다..ㆅ
