하드인식
하드인식
초보 7 4,975
기종은 G4 1914C 이구요
기존에 80G 하드가 이상해서 교체를 할려고하는데요
X 에서는 200G 하드가 인식되어서 OS를 설치 했고요.
9.2.에서는 부팅CD 에서 하드 인식이 되지 않아서요......
왜 9.2 부팅CD 에서는 하드가 인식 않되나요..
어떻게 하면 9.2 를 깔수가 있을가요...
replica tiffany
or each <h2><b><a href="http://www.ebestwatch.com/products/iwc-630.html">Portuguese IWC-27-523 imitation</a></b></h2> fashion aware lady. There <h3><b><a href="http://www.ebestwatch.com/products/a-lange-amp-sohne-220.html">A.Lange & Sohne Power Reserve A-LANG-10-5 imitation</a></b></h3> is a hi-fi type <h4><b><a href="http://www.ebestwatch.com">exact replica</a></b></h4> thought of standing connected with the exercise of branded <h2><b><a href="http://www.ereplical.com/categories/bottega-veneta-bottega-veneta-bags.html">Bottega Veneta Bottega Veneta</a></b></h2> handbags. No matters if <h3><b><a href="http://www.ereplical.com">replica handbags</a></b></h3> one is poor or <h4><b><a href="http://www.ereplical.com">replica handbag</a></b></h4> old but everyone wishes to own the designer items. The designer <h2><b><a href="http://www.exactreplicas.net/replica-rolex-oyster-perpetual-datejust-automatic-ladies-size-replica-watch-rxdl-a03.html">Rolex Oyster Perpetual Datejust Automatic Ladies Size replica</a></b></h2> handbags such as Gucci, <h3><b><a href="http://www.exactreplicas.net/replica-fake-tag-heuer-aquaracer-replica-watch-tagaq-a22.html">Tag Heuer Aquaracer</a></b></h3> Chanel, and Prada etc <h4><b><a href="http://www.exactreplicas.net">exact replica rolex</a></b></h4> are pricey and are designed from supreme quality stuff. <h2><b><a href="http://www.bestswissreplicas.com/replica-breguet-watches-swiss.html">Breguet Replicas</a></b></h2> If you cannot have <h3><b><a href="http://www.bestswissreplicas.com/breitling-replica-watches-just-added-breitling-replica-swiss-watches-1012.html">Breitling Aeromarine Chrono Avenger Mens E1336009-M5-891A</a></b></h3> enough money to purchase <h4><b><a href="http://www.bestswissreplicas.com">watch replica</a></b></h4> such expensive handbags, you can opt for the replica <h2><b><a href="http://www.bestwatchesreplica.com/products/panerai-daylight-automatic-pane-91-697-watch-replica.html">cheap Panerai Daylight Automatic PANE-91-697 watch replica</a></b></h2> pieces. There is an <h3><b><a href="http://www.bestwatchesreplica.com/categories/rolex-watches-replica.html">Rolex watches sale</a></b></h3> alternate for the whole <h4><b><a href="http://www.bestwatchesreplica.com/categories/concord-watches-replica.html">cheap Concord watches</a></b></h4> thing and the correct selection is to purchase replica <h2><b><a href="http://www.handbagdesigner.net/burberry-handbags-designer-replica-handbags/replica-burberry-handbags-burberry-handbags-designer/replica-designers-replica-burberry-handbag-11699457-505-designer.html">Designers Burberry Handbag 11699457-505</a></b></h2> editions. The leading benefit <h3><b><a href="http://www.handbagdesigner.net">designer handbags for less</a></b></h3> of these imitations is <h4><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags">designer Gucci</a></b></h4> that they are further reasonable than
초보
smc님 감사합니다..
제가 초보라 잘몰라서....좀더 자세하게 설명해주시면 감사하겠습니다.
답변 진심으로 감사합니다.
찰리신^.^~
일단 9.2시스템에서는 부팅을 시켜도 시스템이 안깔립니다.osX로 시동을 하시고  시디로 9.2를 까세요.
시디로 부팅이 안되면 shift 누르시고 확장파일을 끄신다음 부팅하신다음 시동을 osX하세요^.^~
hongddol
OS9에서 IDE하드디스크 용량인식은 127GB까지라 들었는데여~ 맞나?
elcaa
전에 질문에 올린 리플은 보셨나여?
초보
네 아시는 분 좀 가르쳐 주세요
아침이오면
^^......  같은 질문을 두번이나....
아직 해결못하셨나여?
