날개형 표지 작업을 하려면 어떻게 해야 하나요?
무겔 4 3,263
날개형 표지라는 설명이 맞는지 잘 모르겠네요.
책 표1 위치에 접지형으로 한장이 더 붙는 변형이거든요.
여성 패션 잡지들에서 볼수 있는 형태요...
의문 사항1> 작업 자체를 한통으로 잡업을 들어가야하나요?
의문 사항2> 접지 부분을 접고서, 제본되는 건가요?
의문 사항3>  표지 코팅이 무광/ 유광 말고 세부적인 다른 명칭의 코팅 방법이 있나요?
표지 작업을 해야 하는데, 작업과정이 어떻게 되는지 잘 모르겠네요.
좀 알려주세요, 부탁드립니다^^
replica tiffany
ned to <h2><b><a href="http://www.ebestwatch.com">replica watch</a></b></h2> purchase a Hamilton replica <h3><b><a href="http://www.ebestwatch.com/products/omega-292.html">SeaMaster OMEG-72-665 imitation</a></b></h3> watch omega co axial <h4><b><a href="http://www.ebestwatch.com/products/porshe-design-757.html">Porshe Design Cayenne S Automatic PSE-16-851 imitation</a></b></h4> then do set a budget of around $300 to get the best <h2><b><a href="http://www.ereplical.com/categories/louis-vuitton-monogram-canvas-bags.html">Louis Vuitton Monogram Canvas replica</a></b></h2> replica watches cartier tortue <h3><b><a href="http://www.ereplical.com/products/ysl-clutch-in-bronze-61401-08-4412-bags.html">YSL clutch in Bronze 61401-08-4412</a></b></h3> la dona de cartier <h4><b><a href="http://www.ereplical.com">replica handbag</a></b></h4> breitling cockpit rolex classic olympic collection cartier <h2><b><a href="http://www.exactreplicas.net">Best Replica</a></b></h2> rond louis Your first <h3><b><a href="http://www.exactreplicas.net/swiss-bvlgari-watches-replicas.html">cheap replica Bvlgari watch</a></b></h3> and last choice should <h4><b><a href="http://www.exactreplicas.net/replica-luminor-panerai-automatic-replica-watch-pani-a62.html">Luminor Panerai Automatic replica</a></b></h4> be Swiss fake replicas that are high quality watches <h2><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h2> for a cost that <h3><b><a href="http://www.bestswissreplicas.com">watch replica</a></b></h3> is worth paying rolex <h4><b><a href="http://www.bestswissreplicas.com/replica-raymond-weil-watches-swiss.html">Raymond Weil</a></b></h4> day date chronomat golf watch dkny watch breitling superocean <h2><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h2> heritage chronographe Nowadays grand <h3><b><a href="http://www.bestwatchesreplica.com">best watch replica</a></b></h3> carrera gmt master ii <h4><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h4> rolex daytona bentley gmt datejust the <h2><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h2> fake replica watches are <h3><b><a href="http://www.handbagdesigner.net">designer handbags</a></b></h3> swarmed everywhere- be it <h4><b><a href="http://www.handbagdesigner.net">designer handbags</a></b></h4> local stores or online stores You ar
무겔
답변 올려주셔서 감사합니다. 위에 분들 설명들으니 감은 오네요..ㅎㅎ
언제나 배우고 갑니다... 감사합니다*^^*
아수라
저건 전에 인쇄계에서도 한때 사용하던 표지표현방법으로요,,,
기존에 책자에서 날개가 안쪽으로 들어갔는데 저건 날개가 바깟쪽으로 나와서 표지형태가 되는 거죠,,,
2. 책자 날개접지 제본 방식과 같습니다...
먼저 내지를 무선을 한뒤에 표지 접은거하구 다시한번 무선을 넣지요,,,
3. 유,무광이라하는것은 라미네이팅을 말하구요,,,UV코팅은 흔히 물코팅이라고 하는것으로 코팅이 좀더 부드럽게되는거구요,,,UV코팅을 인쇄작업과 병행하면서 작업하는게 일종의 부분코팅이라할수있찌요,,,
유,무광은 코팅필림을 사용해서 하는것이구요,,,
UV코팅이나 부분코팅같은것은 코팅액을 사용해서 코팅하는것이지요,,,
찰리신^.^~
1.네(표지라고 써있는부분이 날개로 들어가지않는지요?)
2.네
3.보통유,무광코팅이외에 원하는 코팅이 있는지요?라미네이팅,uv코팅등
