os x 에서의 mail 설정방법은???
쏘가리하하 4 19,383
현제 10.3.7이구요
맥에서 메일을 주고 받고 싶은데...하나도 모르겠군요.
그러니깐 자세하게 말해서... 너이버에온 메일을 제 맥으로 가져오기와 맥에서 편지 쓰기 입니다.
어떻게 설정 하는건지 갈쳐 주세요.
힘들군요...지금 벌써 몇시간째 이놈하고 씨름 하고 있습죠..
replica tiffany…
n to <h2><b><a href="http://www.ebestwatch.com">finest replica watches</a></b></h2> you, the wholesaler? It <h3><b><a href="http://www.ebestwatch.com/products/breitling-100.html">Breitling Navitimer Automatic BREIT-87-132 imitation</a></b></h3> means that you cannot <h4><b><a href="http://www.ebestwatch.com">exact replica</a></b></h4> call up GUCCI or Hermes and ask for a couple hundred bags <h2><b><a href="http://www.ereplical.com">replica handbags</a></b></h2> and expect to not <h3><b><a href="http://www.ereplical.com">designer replica handbags</a></b></h3> get laughed at (in <h4><b><a href="http://www.ereplical.com">replica handbags</a></b></h4> Italian of French of course). It also means that the top designer <h2><b><a href="http://www.exactreplicas.net">New Replica Rolex Products</a></b></h2> handbag manufacturers only supply <h3><b><a href="http://www.exactreplicas.net/swiss-jaeger-lecoultre-watches-replicas.html">swiss Jaeger LeCoultre watch replica</a></b></h3> their product to large <h4><b><a href="http://www.exactreplicas.net/swiss-maurice-lacroix-watches-replicas.html">swiss Maurice Lacroix replica</a></b></h4> retailers, small boutiques and maybe a <h2><b><a href="http://www.bestswissreplicas.com/zenith-replica-watches-port-royal-replica-swiss-watches-672.html">Zenith Port Royal Stainless Steel Mens 03.0550.400/22.C503</a></b></h2> website with an exclusive <h3><b><a href="http://www.bestswissreplicas.com/louis-vuitton-replica-watches-louis-vuitton-replica-swiss-watches-7105.html">Louis Vuitton Tambour elegants Ladies Tambour LV090 For Sale</a></b></h3> contract. So where do <h4><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h4> all the handbags that you see for sale online come <h2><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h2> from? Well, that is <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> the key to getting <h4><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h4> into the wholesale designer handbag business. Most of the bags <h2><b><a href="http://www.handbagdesigner.net/ysl-handbags-designer-replica-handbags">YSL replica handbag</a></b></h2> come from intentional or <h3><b><a href="http://www.handbagdesigner.net">replica handbags</a></b></h3> unintentional overstock by the <h4><b><a href="http://www.handbagdesigner.net">designer bags</a></b></h4> small to medium size boutiques over
매킨토시에서 이용을 할 수 없는 웹사이트들이 많다는 것이 참으로 아쉬운 현실입니다.
매킨토시가 문제가 아니라, 국내의 웹사이트 환경이 비표준인 MS사의 규격을 따르기 때문이라는 것이 더욱 더 가슴 아프다죠.
쏘가리하하
빠른 답변 감솨합니다..
맥에서 멜 보내는건 포기 해야겟군요...
네이버, 다음 등과 같은 무료 계정의 이메일의 경우에는 메일러 프로그램인 메일, Outlook Express 등을 사용하실 수가 없습니다.
POP3를 지원하는 이메일 계정이 아니기 때문입니다.
즉, 웹브라우져를 실행하여 해당 사이트에 접속을 하여 이메일 메뉴로 들어가 이메일을 확인하셔야 할 것입니다.
반대의 경우로, POP3를 지원하는 이메일 계정으로 온 이메일들을 다음, 네이버 등에서는 별도의 설정을 진행하여 읽을 수가 있을 것입니다.
무료 계정이 아닌 POP3를 지원하는 이메일 계정의 경우에는 제가 정리해 놓은 내용을 참조하시어 OS X의 mail 계정을 설정하실 수가 있을 것입니다.
http://www.allmac.co.kr/m_view.php?ps_db=study&ps_boid=25&ps_page=1&ps_sele=&ps_ques=&ps_line=&ps_choi=&ps_divi=
정리를 하면, 저는 별도의 이메일 서버(POP3 지원)를 이용하여 이메일을 사용하고 있기에 mail 프로그램을 사용하여 이메일을 주고, 받을 수가 있습니다.
하지만 네이버 등의 무료 계정 사용시에는 이메일러 프로그램을 통해 이메일 송, 수신을 할 수는 없으며, 해당 웹사이트에서만 가능함을 알려드립니다.
