맥외장하드
맥외장하드
코코맥
주변
3
5,556
2008.11.07 14:03
새로텍 하드박스에서 외장하드(SATA HDD)를 구립했는데요
맥에 연결했더니 호환은 되는데 너무 느려요...
혹시 뭐가 문제인가요?
전에건(어느모델인지 잘모름) 파일 찾는것도 빠르고 복사도 빨랐거든요..
sfgsdf
2010.04.12 15:17
es durable, <h2><b><a href="
http://www.cartierreplicawatch.net/a-lange-sohne-datograph-flyback-mens-watch-403-035-replica-cartier.html"
>A Lange & Sohne Datograph Flyback Mens 403.035 imitations</a></b></h2> long lasting furniture. A <h3><b><a href="
http://www.cartierreplicawatch.net/chanel-j12-chronograph-mens-watch-h1008-replica-cartier.html"
>Chanel J12 Chronograph Mens H1008</a></b></h3> good supplier will be an expert <h2><b><a href="
http://www.lreplical.com/categories/louis-vuitton-bags.html"
>Louis Vuitton Handbags outlet</a></b></h2> on trade furniture for <h3><b><a href="
http://www.lreplical.com"
>Leather Handbags</a></b></h3> every use and will attend to your <h2><b><a href="
http://www.ireplical.com"
>designer handbags</a></b></h2> needs. You will have <h3><b><a href="
>designer replica bags</a></b></h3> your furniture for a long time, so it <h2><b><a href="
http://www.bestswissreplicas.com/breitling-replica-watches-windrider-replica-swiss-watches-1126.html"
>Discount Breitling Windrider Chronomat Evolution Diamond Steel Mens A1335653-A5-447</a></b></h2> is important to approach <h3><b><a href="
http://www.bestswissreplicas.com/tag-heuer-replica-watches-link-replica-swiss-watches-2738.html"
>Tag Heuer Link Automatic Chronometer WJF5111.BA0570</a></b></h3> this relationship as you would any <h2><b><a href="
http://www.bestwatchesreplica.com"
>watch replica</a></b></h2> long term business relationship. <h3><b><a href="
http://www.bestwatchesreplica.com/products/vacheron-constantin-perpetual-calendar-v-const-51-998-watch-replica.html"
>cheap Vacheron Constantin Perpetual Calendar V_CONST-51-998 watch replica</a></b></h3> 3. Pay special attention to <h2><b><a href="
http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags"
>Mulberry</a></b></h2> the waiting area. It <h3><b><a href="
http://www.handbagdesigner.net/marc-jacobs-handbags-designer-replica-handbags"
>Marc Jacobs handbags</a></b></h3> does not matter whether you are
es durable, <h2><b><a href="http://www.cartierreplicawatch.net/a-lange-sohne-datograph-flyback-mens-watch-403-035-replica-cartier.html">A Lange & Sohne Datograph Flyback Mens 403.035 imitations</a></b></h2> long lasting furniture. A <h3><b><a href="http://www.cartierreplicawatch.net/chanel-j12-chronograph-mens-watch-h1008-replica-cartier.html">Chanel J12 Chronograph Mens H1008</a></b></h3> good supplier will be an expert <h2><b><a href="http://www.lreplical.com/categories/louis-vuitton-bags.html">Louis Vuitton Handbags outlet</a></b></h2> on trade furniture for <h3><b><a href="http://www.lreplical.com">Leather Handbags</a></b></h3> every use and will attend to your <h2><b><a href="http://www.ireplical.com">designer handbags</a></b></h2> needs. You will have <h3><b><a href="http://www.ireplical.com">designer replica bags</a></b></h3> your furniture for a long time, so it <h2><b><a href="http://www.bestswissreplicas.com/breitling-replica-watches-windrider-replica-swiss-watches-1126.html">Discount Breitling Windrider Chronomat Evolution Diamond Steel Mens A1335653-A5-447</a></b></h2> is important to approach <h3><b><a href="http://www.bestswissreplicas.com/tag-heuer-replica-watches-link-replica-swiss-watches-2738.html">Tag Heuer Link Automatic Chronometer WJF5111.BA0570</a></b></h3> this relationship as you would any <h2><b><a href="http://www.bestwatchesreplica.com">watch replica</a></b></h2> long term business relationship. <h3><b><a href="http://www.bestwatchesreplica.com/products/vacheron-constantin-perpetual-calendar-v-const-51-998-watch-replica.html">cheap Vacheron Constantin Perpetual Calendar V_CONST-51-998 watch replica</a></b></h3> 3. Pay special attention to <h2><b><a href="http://www.handbagdesigner.net/mulberry-handbags-designer-replica-handbags">Mulberry</a></b></h2> the waiting area. It <h3><b><a href="http://www.handbagdesigner.net/marc-jacobs-handbags-designer-replica-handbags">Marc Jacobs handbags</a></b></h3> does not matter whether you are
2008.11.07 18:55
G4에서 외장이 느린이유는 USB로 연결하는 외장케이스이기 때문입니다.
그이유는 G4에서는 USB 2.0으로 작동이 안되고 1.1에 속도로 사용이 되기 때문에 느린겁니다
그래서 G4에서는 반드시 파이어와이어(IEEE1394)포트를 지원하는 외장케이스로 구입을 해서 사용해야 됩니다.
새로텍 제품중에는 354USF 케이스가 파이어와이어+USB가 모두 지원되는 콤보 케이스 입니다.
하드는 시게이트 500GB하드등을 많이 사용합니다.
단.2.5" 노트북용 하드가 들어가는 케이스는 오직 USB방식만 판매가 되기 때문에 어쩔수 없이 큰외장하드(3.5")케이스로 하셔야 됩니다.
G4에서 외장이 느린이유는 USB로 연결하는 외장케이스이기 때문입니다. 그이유는 G4에서는 USB 2.0으로 작동이 안되고 1.1에 속도로 사용이 되기 때문에 느린겁니다 그래서 G4에서는 반드시 파이어와이어(IEEE1394)포트를 지원하는 외장케이스로 구입을 해서 사용해야 됩니다. 새로텍 제품중에는 354USF 케이스가 파이어와이어+USB가 모두 지원되는 콤보 케이스 입니다. 하드는 시게이트 500GB하드등을 많이 사용합니다. 단.2.5" 노트북용 하드가 들어가는 케이스는 오직 USB방식만 판매가 되기 때문에 어쩔수 없이 큰외장하드(3.5")케이스로 하셔야 됩니다. =================== 도움이 필요하시면 베스트맥(A/S,판매)를 클릭하고 자기소개를 참고하세요
2008.11.07 14:51
USB방식으로 연결해서 사용하거나 포맷이 맥전용이아니라 PC,맥겸용인FAT32로 포맷 되어있으면 속도가 느립니다. 파이어와이어(1394)방식으로 그리고 데이타안전성을 고려해서 맥전용으로 포맷해서 사용해보세요..
USB방식으로 연결해서 사용하거나 포맷이 맥전용이아니라 PC,맥겸용인FAT32로 포맷 되어있으면 속도가 느립니다. 파이어와이어(1394)방식으로 그리고 데이타안전성을 고려해서 맥전용으로 포맷해서 사용해보세요.. ++++++++++++++++++++++++++++++++++++++++++ "맥사이트(A/S점/복구)"아이디 누르고 (자기소개)클릭후 내용을 참조하세요..
삭제
수정
32 명
1,339 명
1,726 명
14,943,223 명
180,035 명
