도와주세요
도와주세요
김썬 3 3,908
시동키누르면 물음표만 뜨고 다음으로 않넘어가요...
도와주세요
아님 충남 서산에 맥 A/S해주시는 분좀... 타지역에서 출장오실수 있으신 분도 괜찮고요....
replica tiffany
Boat Watches,Ferrari <h2><b><a href="http://www.ebestwatch.com/products/tag-heuer-369.html">Tag Heuer Link Quartz Midsize T_HEU-33-918 imitation</a></b></h2> Watches,Longines Watches .......... inasmuch <h3><b><a href="http://www.ebestwatch.com/categories/chopard-replicas.html">imitation Chopard watches</a></b></h3> as on ,don't wait <h4><b><a href="http://www.ebestwatch.com">replica watches for sale</a></b></h4> again reckon with , <h2><b><a href="http://www.ereplical.com">replica handbags</a></b></h2> our openwork : swissmirrorwatch.com <h3><b><a href="http://www.ereplical.com">replica handbags</a></b></h3> Being an careful shopper <h4><b><a href="http://www.ereplical.com">designer replica handbags</a></b></h4> isn't true noted over your grant jail bait <h2><b><a href="http://www.exactreplicas.net">Best Replicas</a></b></h2> of thesis. By subscribing <h3><b><a href="http://www.exactreplicas.net/replica-oris-williams-f1-team-chronograph-quartz-replica-watch-oris-a25.html">Oris Williams F1 Team Chronograph Quartz  replica</a></b></h3> to the clue mastery <h4><b><a href="http://www.exactreplicas.net">replica watches</a></b></h4> this device you'll be empiricism your paltry part to <h2><b><a href="http://www.bestswissreplicas.com/tag-heuer-replica-watches-link-replica-swiss-watches-2750.html">Tag Heuer Link Diamond 18kt Yellow Gold and Steel Ladies WJF1354.BB0581 for sale</a></b></h2> set up the globe <h3><b><a href="http://www.bestswissreplicas.com">replica watches</a></b></h3> a more fitting provide. <h4><b><a href="http://www.bestswissreplicas.com/louis-vuitton-replica-watches-louis-vuitton-replica-swiss-watches-7105.html">Louis Vuitton Tambour elegants Ladies Tambour LV090</a></b></h4> You blame and footslog the streets proudly astute that the <h2><b><a href="http://www.bestwatchesreplica.com/categories/concord-watches-replica.html">replica Concord watches</a></b></h2> purse on your ferry <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> isn't compromising your rainless <h4><b><a href="http://www.bestwatchesreplica.com/categories/concord-watches-replica.html">fake Concord watches</a></b></h4> conscious. Elegant Breitling facsimile watches that <h2><b><a href="http://www.handbagdesigner.net">handbags for less</a></b></h2> are exact, from the <h3><b><a href="http://www.handbagdesigner.net/new-dior-handbags-designer-replica-handbags">NEW Dior</a></b></h3> irons to the dials <h4><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags">Gucci handbags</a></b></h4> to the bezel, knobs besides chorography. Breitlin
*OS CD로 부팅후 CD안에 유틸리티안에 보시면 Disk First Aid(OSX인경우 상단메뉴바에서 디스크유틸리티로 들어가서 하드권한/복구)라는 프로그램으로 복구해보세요.( 그래도 해결이 안되면 복구서비스를 받으셔야 합니다.)
부팅시 화면가운데에서 "?"가 뜨는 증상은 부팅시스템을 못찾아서 나오는 문제 입니다.
다운되면서 하드디스크에 포맷이 깨져서 하드가 마운트 안되기 때문에 그안에 있는 한글시스템을 읽지 못하는 겁니다.
물론 하드디스크에서 딸깍딸깍 하는 소리가 나면서 하드가 돌지 않는 경우에는 하드 불량이라 복구가 어렵고요.(하드를 교체 하셔야 됩니다.)
만약 하드디스크가 기계적으로 고장난것이 아니면 부팅시스템을 못찾는 이유가 시스템에 문제가 있는 경우가 아니고요.
결론적으로 하드 복구를 해야 됩니다.
http://kmug.co.kr/board/view_info2.php?member_no=10050
