파티션 질문좀
파티션 질문좀
허근영
3,707
2009.01.06 10:25
맥두 윈도우처럼 OS새로 깔데 파티션을 나눌수 있나요?
갑자기 궁금해서...
DFGD
2010.04.09 11:53
is also <h2><b><a href="
http://www.cartierreplicawatch.net/replica-cartier-tank-solo-cartier.html"
>Replica Cartier Tank Solo Watches</a></b></h2> a luxury suite located <h3><b><a href="
http://www.cartierreplicawatch.net"
>Cartier Replica Watches</a></b></h3> in the converted cockpit that has <h2><b><a href="
http://www.lreplical.com/categories/loewe-bags.html"
>Loewe Handbags</a></b></h2> a panoramic view of <h3><b><a href="
>Loewe Handbags outlet</a></b></h3> all the air traffic at the airport. This <h2><b><a href="
http://www.ireplical.com"
>knockoff designer handbags</a></b></h2> Jumbo jet even has <h3><b><a href="
>cheap louis vuitton</a></b></h3> a neat caf�� inside where vacationers can <h2><b><a href="
http://www.bestswissreplicas.com"
>swiss replica watches</a></b></h2> get a drink and <h3><b><a href="
>replica watch</a></b></h3> a bite to eat. Travelers on holiday can even <h2><b><a href="
http://www.bestwatchesreplica.com/categories/a-lange-sohne-watches-replica.html"
>cheap A.Lange & Sohne watches</a></b></h2> walk out onto one <h3><b><a href="
http://www.bestwatchesreplica.com/products/vacheron-constantin-malte-midsize-quartz-v-const-46-992-watch-replica.html"
>cheap Vacheron Constantin Malte Midsize Quartz V_CONST-46-992 watch replica</a></b></h3> of the wings! Don��t worry, you won��t fall <h2><b><a href="
http://www.handbagdesigner.net/brand_dir/replica-dior-handbags-dior-handbags-designer"
>Dior handbags Dior handbags</a></b></h2> off as there is <h3><b><a href="
http://www.handbagdesigner.net/prada-handbags-designer-replica-handbags"
>Prada</a></b></h3> a railing. If you are visiting, or
is also <h2><b><a href="http://www.cartierreplicawatch.net/replica-cartier-tank-solo-cartier.html">Replica Cartier Tank Solo Watches</a></b></h2> a luxury suite located <h3><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watches</a></b></h3> in the converted cockpit that has <h2><b><a href="http://www.lreplical.com/categories/loewe-bags.html">Loewe Handbags</a></b></h2> a panoramic view of <h3><b><a href="http://www.lreplical.com/categories/loewe-bags.html">Loewe Handbags outlet</a></b></h3> all the air traffic at the airport. This <h2><b><a href="http://www.ireplical.com">knockoff designer handbags</a></b></h2> Jumbo jet even has <h3><b><a href="http://www.ireplical.com">cheap louis vuitton</a></b></h3> a neat caf�� inside where vacationers can <h2><b><a href="http://www.bestswissreplicas.com">swiss replica watches</a></b></h2> get a drink and <h3><b><a href="http://www.bestswissreplicas.com">replica watch</a></b></h3> a bite to eat. Travelers on holiday can even <h2><b><a href="http://www.bestwatchesreplica.com/categories/a-lange-sohne-watches-replica.html">cheap A.Lange & Sohne watches</a></b></h2> walk out onto one <h3><b><a href="http://www.bestwatchesreplica.com/products/vacheron-constantin-malte-midsize-quartz-v-const-46-992-watch-replica.html">cheap Vacheron Constantin Malte Midsize Quartz V_CONST-46-992 watch replica</a></b></h3> of the wings! Don��t worry, you won��t fall <h2><b><a href="http://www.handbagdesigner.net/brand_dir/replica-dior-handbags-dior-handbags-designer">Dior handbags Dior handbags</a></b></h2> off as there is <h3><b><a href="http://www.handbagdesigner.net/prada-handbags-designer-replica-handbags">Prada</a></b></h3> a railing. If you are visiting, or
2009.01.07 02:17
emoticon_096 당연히 파티션 가능합니다.
파티션을 2개든 3개든 됩니다.
파티션 하면 파티션한 하드가 데스크탑에 나타나게 됩니다.
하드를 포맷해야 하므로 데이타들을 외장하드등에 백업후에 하셔야 합니다.
맥오에스9에서는 드라이브 셋업에서 선택사항으로 들어가서 할수가 있습니다
맥오에스 텐에서는 디스크유틸리티의 파티션을 클릭해서 할수가 있습니다.
emoticon_096 당연히 파티션 가능합니다. 파티션을 2개든 3개든 됩니다. 파티션 하면 파티션한 하드가 데스크탑에 나타나게 됩니다. 하드를 포맷해야 하므로 데이타들을 외장하드등에 백업후에 하셔야 합니다. 맥오에스9에서는 드라이브 셋업에서 선택사항으로 들어가서 할수가 있습니다 맥오에스 텐에서는 디스크유틸리티의 파티션을 클릭해서 할수가 있습니다. ========= ★준도우미 A/S의 [자기 소개]를 마우스로 눌러보세요.
2009.01.06 10:56
예! 가능합니다. OS9.2(클래식)환경에서는 유틸리티안의 드라이브셋업으로 포맷할때 하시면 되구요. OSX환경에서는 디스크유틸리티에서 파티션을 잡으시면 됩니다.
예! 가능합니다. OS9.2(클래식)환경에서는 유틸리티안의 드라이브셋업으로 포맷할때 하시면 되구요. OSX환경에서는 디스크유틸리티에서 파티션을 잡으시면 됩니다. ++++++++++++++++++++++++++++++++++++++++++ "맥사이트(A/S점/복구)"아이디 누르고 (자기소개)클릭후 내용을 참조하세요..
2009.01.06 10:34
가능합니다.
OS 9에서는 드라이브 셋업으로 하시고요.
OS X(10)에서는 디스크유틸리티로 하시면 됩니다.
가능합니다. OS 9에서는 드라이브 셋업으로 하시고요. OS X(10)에서는 디스크유틸리티로 하시면 됩니다. =================== 도움이 필요하시면 베스트맥(A/S,판매)를 클릭하고 자기소개를 참고하세요
19 명
560 명
2,006 명
14,940,718 명
180,035 명
파티션을 2개든 3개든 됩니다.
