맥 본체에서 하드 빼는거 어떻게 하나요?
개미소다 8 9,635
맥은 G4 퀵실버를 쓰고있습니다.
물음표가 떠서 CD로부팅도 해봤는데요
CD부팅도 안되고 외장하드로 부팅도 안되네요ㅠ;;
그래서 하드 때서 외장하드로 연결해서 설치하려고하는데
열어보니 ...
어떻게 분리하는걸까요?
이틀동안 죽것습니다..ㅠㅠ
자세한 답변 부탁드립니다.
replica tiffany
you step <h2><b><a href="http://www.ebestwatch.com/products/hamilton-928.html">exact replica Khaki X-Wind HM-6-462</a></b></h2> independent shroud a Louis <h3><b><a href="http://www.ebestwatch.com/products/panerai-895.html">exact replica Panerai Luminor Slytech Automatic PANE-83-695</a></b></h3> Vuitton replica handbag.Try out <h4><b><a href="http://www.ebestwatch.com/products/concord-743.html">exact replica Concord C1 Chronograph CC-1-408</a></b></h4> the sweltering or the coal Murakami Louis <h2><b><a href="http://www.ereplical.com/products/dior-cannage-nylon-drawstring-tote-black-1845-bags.html">Dior Cannage Nylon Drawstring Tote-Black-1845</a></b></h2> Vuitton replica handbags, Louis <h3><b><a href="http://www.ereplical.com/products/chanel-1112-pink-and-silver-chain-1318-bags.html">Chanel 1112-Pink and Silver Chain-1318</a></b></h3> Vuitton replica bags I <h4><b><a href="http://www.ereplical.com/products/marc-jacobs-352065-blue-352065-2-4158-bags.html">Marc Jacobs 352065-Blue 352065-2-4158</a></b></h4> would have never guessed who the mastermind behind <h2><b><a href="http://www.exactreplicas.net">replica watches</a></b></h2> the Jimmy-Choo handbags was <h3><b><a href="http://www.exactreplicas.net">designer replica watches</a></b></h3> by. Recently, I found <h4><b><a href="http://www.exactreplicas.net">cheap replica rolex</a></b></h4> head and heal in love with the Burberry Scarf <h2><b><a href="http://www.bestswissreplicas.com">replica watch</a></b></h2> too. This is precisely <h3><b><a href="http://www.bestswissreplicas.com/omega-replica-watches-constellation-my-choice-replica-swiss-watches-5063.html">Discount Omega Constellation My Choice Quartz Mini Ladies 1566.76.00</a></b></h3> why I love the <h4><b><a href="http://www.bestswissreplicas.com">swiss replica watches</a></b></h4> Burberry replica handbags. Burberry has its unique pattern, <h2><b><a href="http://www.bestwatchesreplica.com/products/breguet-classic-mechanical-br-21-80-watch-replica.html">cheap Breguet Classic Mechanical BR-21-80 watch replica</a></b></h2> Cashmere trimmed with each <h3><b><a href="http://www.bestwatchesreplica.com/products/omega-de-ville-co-axial-omeg-61-638-watch-replica.html">cheap Omega De Ville Co-Axial OMEG-61-638 watch replica</a></b></h3> other. Our stunning replica <h4><b><a href="http://www.bestwatchesreplica.com">best watches replica</a></b></h4> Burberry handbags has sleek exterior make <h2><b><a href="http://www.handbagdesigner.net/jimmy-choo-handbags-designer-replica-handbags">Jimmy Choo</a></b></h2> you speechless. You will <h3><b><a href="http://www.handbagdesigner.net/gucci-handbags-designer-replica-handbags/replica-gucci-handbags-gg-fabric-designer/replica-replica-designers-handbags-153009-black-designer.html">Designers Handbags 153009-Black</a></b></h3> intersely missing the Replica <h4><b><a href="http://www.handbagdesigner.net/miumiu-handbags-designer-replica-handbags">MiuMiu</a></b></h4> Handbags. Our website perhaps remind y
replica tiffany
질문과 답 토마토맥 >> 질문과 답
답변을 해주시는 분들도 해결이 되었는지 정말 궁금하답니다^^
해결이 되었거나 하시면 바로 해결되었다는 글을 적는 센쓰! 아셨죠?^^
  [기타] 맥 본체에서 하드 빼는거 어떻게 하나요? 2009-12-01 18:34:06
  이름 : 개미소다
  쪽지보내기
  이름으로 검색
  메일보내기
  자기소개
  아이피 : 211.♡.246.153
  조회 : 636
맥은 G4 퀵실버를 쓰고있습니다.
열어보니 ...
어떻게 분리하는걸까요?
이틀동안 죽것습니다..ㅠㅠ
자세한 답변 부탁드립니다.
개미소다
(1)
  쪽지보내기
  이름으로 검색
  메일보내기
  자기소개
09-12-01 18:42
옆뚜껑을 열어서 아래 보시면 하드디스크가 안쪽 바닥에 있습니다.
뒤에 데이타선과 파워선을 빼고 나사 하나만 풀면 빠집니.
61.♡.90.137
  쪽지보내기
  이름으로 검색
  메일보내기
  자기소개
09-12-01 18:42
본체 옆뚜껑 열면 우측하단에 내장하드가 보입니다. 전원케이블 제거후 내장하드에 연결된 케이블(두가지) 제거후 가이드 고정된 나사풀고 빼내시면 됩니다.그리어렵지 않습니다.
211.♡.209.131
  쪽지보내기
  이름으로 검색
  메일보내기
  자기소개
09-12-01 18:43
"?"가 뜬다는 것은 부팅시스템이 없다는 표시 입니다.
다시말해서 부팅시 화면가운데에서 "?"가 뜨는 증상은 부팅시스템을 못찾아서 나오는 문제 입니다.
이런경우 한글시스템에 문제가 있어서 나오는 현상이 아닌경우가 대부분 입니다.
거의다 다운되면서 하드디스크에 포맷이 깨져서 하드가 마운트 안되기 때문에 그안에 있는 한글시스템을 읽지 못하는 겁니다.
하드에 포맷이나 볼륨을 복구해야 하드가 데스크탑에 마운트 됩니다.
이런 문제가 자주 생기는 이유는 대표적으로 3가지 입니다.
1.하드가 노후화된 경우 입니다.
2.하드에 포맷이 불안한경우
3.메모리관련 문제 입니다.
내장메모리가 너무 적거나 각각에 프로그램 마다 사용메모리를 너무 적게 잡고 사용하시면 큰데이타를 오픈하거나 프로그램을 동시에 많이 열면 느려지기 때문에 다운이 자주 되면서 포맷이 깨집니다.
그래서 G4인경우 내장메모리는 1GB~1.5GB정도는 되어야 되고요.
메모리 셋팅 방법은 아래 링크 참고요.
http://kmug.co.kr /board/zboard.php?id=macos9qa&page=1&sn1=&divpage=2& sn=off&ss=on&sc=on&keyword=메모리&select_arrange=headnum& amp;desc=asc&no=5918
프로그램마다 사용메모리를 충분이 올려주셔야 됩니다.(내장메모리양에 따라)
61.♡.90.137
  쪽지보내기
  이름으로 검색
  메일보내기
  자기소개
09-12-01 18:44
OS CD로 부팅후 CD안의 유틸리티안에 보시면 Disk First Aid(OSXCD인경우 상단메뉴바에서
디스크유틸리티로 들어가서 하드검사/복구에서 디스크권한및복구)라는 프로그램으로 하드를점검/복구해보세요.( 그래도 해결이 안되면 별도의 복구서비스를 받으셔야 합니다.) 노턴은 가급적 돌리지마세요.잘못하면 멀쩡한 데이타도 변형되어서 손상을 입거나 복구가 안될수도 있습니다.
211.♡.209.131
  [준도우미[A/S, 복구등 (ljmactoma)]
  쪽지보내기
  이름으로 검색
  메일보내기
  자기소개
09-12-01 18:46
[emoticon_096] 드를 빼는것은 간단합니다.
본체 전원을 끄고..
본체 우측면의 고리모양의 손잡이를 잡아당겨서 여세요.
그리고 바닥에 보시면 직사각형모양의 내장하드가 보일것입니다.
하드에 연결된 넓은 데이타 케이블과 전원케이블(노란색, 검정색..등 선으로 됨)을 먼저 빼세요.
그리고 드라이버로 중앙에 있는 나사를 풀고..하드 가드를 통채로 빼내세요.
그리고. 하드 가드에서 나사를 풀고 하드를 빼내면 됩니다.
하지만..현재 물음표로 부팅안되는것때문에 하드를 뺄필요는 없고..
부팅시스템 CD를 확실히가지고 계시다면..
CD를 넣고..시동을 하세요.
시동시 바로 키보드 옵션키를 누른채로 기다리세요.
화면에 부팅장치가 나오고.여기서 CD를 선택부팅을 하세요.
CD로 부팅해서 CD안>Applications(MacOS9)>유틸리티를 열고 Disk First Aid로 하드를 검사 복구를 해보세요.
Disk First Aid 로 3번정도 더 해보세요.
한번에 안되고 3번정도 하면 복구되는 경우도 있습니다.
그래도 안된다면..
MacOS X CD로 부팅을 하거나,, MacOS X 시스템이 설치된 맥에 내장하드를 연결해서 MacOS X 에 있는 디스크유틸리티로 복구를 해보세요.
만약 여기서도 안된다면..
상황에 따라서는 별도 복구서비스를 받으셔야 합니다.
물론, 중요한 데이타가 없다면..과감히 CD안의 드라이브 셋업을 실행해서 내장하드를 지우기(포맷)를 한후에 다시 한글시스템으 설치해서 사용을 하시며 됩니다.
단, 이 모든것은 하드가 기계적으로 고장이 없다는 전제입니다.
만약, 하드가 기계적인 고장이라면 새하드를 구매해서 교체 장착후 사용하셔야 합니다.
하드는 3.5인치 일반 E-IDE하드로 구매하시면 됩니다.
118.♡.153.64
  개미소다
  쪽지보내기
  이름으로 검색
  메일보내기
  자기소개
09-12-03 00:10
시디로 부팅이 안되요..ㅜㅠ;;
시디 넣구 C눌렸는데도 안되네요..;;
답변 감사합니다.
58.♡.102.220
  913cd4cf13    이모티콘 사용
[emoticon_001] [emoticon_002] [emoticon_003] [emoticon_004] [emoticon_005] [emoticon_006] [emoticon_007] [emoticon_008] [emoticon_009] [emoticon_010] [emoticon_011] [emoticon_012] [emoticon_013] [emoticon_014] [emoticon_015] [emoticon_016] [emoticon_017] [emoticon_018] [emoticon_019] [emoticon_020]
[emoticon_021] [emoticon_022] [emoticon_023] [emoticon_024] [emoticon_025] [emoticon_026] [emoticon_027] [emoticon_028] [emoticon_029] [emoticon_030] [emoticon_031] [emoticon_032] [emoticon_033] [emoticon_034] [emoticon_035] [emoticon_036] [emoticon_037] [emoticon_038] [emoticon_039] [emoticon_040]
[emoticon_041] [emoticon_042] [emoticon_043] [emoticon_044] [emoticon_045] [emoticon_046] [emoticon_047] [emoticon_048] [emoticon_049] [emoticon_050] [emoticon_051] [emoticon_052] [emoticon_053] [emoticon_054] [emoticon_055] [emoticon_056] [emoticon_057] [emoticon_058] [emoticon_059] [emoticon_060]
[emoticon_061] [emoticon_062] [emoticon_063] [emoticon_064] [emoticon_065] [emoticon_066] [emoticon_067] [emoticon_068] [emoticon_069] [emoticon_070] [emoticon_071] [emoticon_072] [emoticon_073] [emoticon_074] [emoticon_075] [emoticon_076] [emoticon_077] [emoticon_078] [emoticon_079] [emoticon_080]
[emoticon_081] [emoticon_082] [emoticon_083] [emoticon_084] [emoticon_085] [emoticon_086] [emoticon_087] [emoticon_088] [emoticon_089] [emoticon_090] [emoticon_091] [emoticon_092] [emoticon_093] [emoticon_094] [emoticon_095] [emoticon_096] [emoticon_097] [emoticon_098] [emoticon_099] [emoticon_100]
[emoticon_101] [emoticon_102] [emoticon_103] [emoticon_104] [emoticon_105] [emoticon_106] [emoticon_107] [emoticon_108] [emoticon_109] [emoticon_110] [emoticon_111] [emoticon_112] [emoticon_113] [emoticon_114] [emoticon_115] [emoticon_116] [emoticon_117] [emoticon_118] [emoticon_119] [emoticon_120]
Emoticons (C) nate.com
[ 전체(10675) ] [ 하드(701) ] [ 주변(604) ] [ 시스템(2082) ] [ 인터넷(420) ] [ 웹관련(81) ] [ 네트웍(211) ] [ 편집(2519) ] [ 그래픽(1136) ] [ 영상(98) ] [ 음악(57) ] [ 서체(889) ] [ 디자인(431) ] [ 기타(1438) ]
게시물 10,675건
No 분류 제목 이름 날짜 조회
10185
개미소다
시디로 부팅이 안되요..ㅜㅠ;;
답변 감사합니다.
emoticon_096 드를 빼는것은 간단합니다.
본체 전원을 끄고..
CD를 넣고..시동을 하세요.
그래도 안된다면..
만약 여기서도 안된다면..
1.하드가 노후화된 경우 입니다.
2.하드에 포맷이 불안한경우
3.메모리관련 문제 입니다.
http://kmug.co.kr/board/zboard.php?id=macos9qa&page=1&sn1=&divpage=2&sn=off&ss=on&sc=on&keyword=메모리&select_arrange=headnum&desc=asc&no=5918
