OS-X에서 노턴 시스템 웍을 설치하면...
이문영 7 3,991
하드를 인식 못하기 때문에, 하드를 정리할 수가 없네요.
하드정리를 거의 1년 가까이 못 했기 때문에, 정리를 해야겠는데...
어떻게 하면 할 수 있는지 부탁드립니다.
노턴이 안 되면, 다른 프로그램은 뭐가 좋을까요?
replica watches
example, <h2><b><a href="http://www.omegareplicawatch.net/roger-dubuis-replica-omega.html">fake Roger Dubuis watch</a></b></h2> or search for cover <h3><b><a href="http://www.omegareplicawatch.net/omega-seamaster-aqua-terra-150m-ladies-watch-2577-80-replica.html">Omega Seamaster Aqua Terra 150M Ladies 2577.80</a></b></h3> letter tips online. Although <h4><b><a href="http://www.omegareplicawatch.net">replica watches</a></b></h4> most sample <h2><b><a href="http://www.onreplicas.com">knockoffs handbags</a></b></h2> cover letters wont cover <h3><b><a href="http://www.onreplicas.com/wallet-replica-handbags/dior/1167.html">replica handbags Dior Buckle Continental Short Wallet Camel for sale</a></b></h3> your specific abilities  <h4><b><a href="http://www.onreplicas.com">Cheap Louis Vuitton</a></b></h4> and skills, <h2><b><a href="http://www.enreplicas.com/replica-wallet/chanel/chanel-wallet-white-c1506.html">Chanel Wallet White C1506</a></b></h2> it can be adequate <h3><b><a href="http://www.handbagsfake.com">Louis Vuitton fake handbags</a></b></h3> to get you started. <h4><b><a href="http://www.enreplicas.com/replica-coach-handbags/coach-handbags/coach-hampton-signature-carryall-large-beige.html">Coach Hampton Signature Carryall Large - Beige</a></b></h4> Good luck finding <h2><b><a href="http://www.bestswissreplicas.com/replica-parmigiani-watches-swiss.html">Parmigiani</a></b></h2> your dream job!If you <h3><b><a href="http://www.bestswissreplicas.com">replica watch</a></b></h3> are working as a <h4><b><a href="http://www.bestswissreplicas.com/replica-parmigiani-watches-swiss.html">Parmigiani</a></b></h4> freelancer, then the <h2><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h2> greatest benefit that you <h3><b><a href="http://www.bestwatchesreplica.com">watches replica</a></b></h3> get is the working <h4><b><a href="http://www.bestwatchesreplica.com/products/tag-heuer-ayrton-senna-link-quartz-chronograph-t-heu-62-942-watch-replica.html">cheap Tag Heuer Ayrton Senna Link Quartz Chronograph T_HEU-62-942 watch replica</a></b></h4> hours. Nobody <h2><b><a href="http://www.cartierreplicawatch.net">Cartier Watch</a></b></h2> can force you to <h3><b><a href="http://www.cartierreplicawatch.net">Cartier Watches</a></b></h3> do work at the <h4><b><a href="http://www.cartierreplicawatch.net">Cartier Replica Watch</a></b></h4> specific times, it i
이문영
좋은 정보 감사합니다.
지금 나타나고 있는 증상과 관련된 자료를 찾아보다가 OS X 10.4.x에서는 써드 파티의 하드디스크 관리 유틸리티를 사용하지 않는 것이 좋다는 내용의 글이 애플사 홈페이지에 올려져 있는 것을 알게 되었습니다.
아울러 OS X 설치시에 기본으로 설치가 되는 애플사의 디스크 유틸리티도 10.4.x에서는 10.4.x에서 제공되는 디스크 유틸리티를 사용할 것으로 권하고 있으며, 아무리 안돼도 OS X 10.3.9 버전 이상의 OS에서 제공되는 디스크 유틸리티를 사용할 것을 권하고 있습니다.
만약 10.3 CD에 들어 있는 디스크 유틸리티를 10.4에 대하여 사용하는 경우에도 문제가 발생할 소지가 있다고 합니다.
그리고 며칠 전에 저희 거래처에 계신 분이 10.4에서 노턴 부팅 CD로 부팅을 하였으나 하드디스크를 인식하지 못한다는 이야기를 하시더라구요.
아마도 노턴 제품이 10.4를 원활하게 지원하지 못하고 있는 듯이 여겨지면, 이와 관련해서 도움이 될 만한 참고 자료를 찾아보기는 했으나 그 어디에서도 유용한 내용을 찾을 수가 없네요.
따라서 노턴을 사용한 하드디스크 관리는 유보를 하시고, OS X에서 자체 제공하는 디스크 유틸리티를 사용하시어 권한 복구 및 디스크 복구를 진행하는 선에서 관리를 그치는 것이 좋을 듯합니다.
이문영
작업은 optimization 및 directory 정리죠...
Disk warrior 3.0으로 해 봤는데, directory에 문제가 있다고 나오는데, 수정은 못하더군요.  역시 disk warrior CD로는 부팅이 안 되고요.
이문영
사용시스템은 OS-X 10.4.5입니다.  노턴 system works 2.0이나 3.0 둘다 설치해도, 하드를 하나도 인식을 못 합니다.
현재 내장하드는 파티션해서, 두개, 외장하드 3개를 firewire로 달아놨는데...어느 하나 인식을 못합니다.
또 한가지, systemworks CD로 부팅을 못 합니다.  OS-X에서 CD를 시스템 시디로 인식을 못 하더군요..
지금 인식하지 못하고 있는 하드디스크는 어떤 하드디스크인지요?
매킨토시 내장 하드디스크인지요?
그리고 '정리'라는 말의 의미가 포맷인가요, 아니면 Speed Disk(PC에서는 조각 모음)를 의미하는 것인가요?
좀 더 정확한 상황 설명과 하드디스크에 대해 어떤 작업을 하시고자 하는 것인지에 대한 언급이 있으시면 답글을 올리기에 수월하지 않을까 합니다.
맥바보
일단 시스템이 뭔지를.....클래식에서 하드 인식인 안된다면 노턴을 먼저 돌려 보는 것도 괜찬겠죠...(노턴으로 구동해서 말이죠)...그래도 안된다면 시스템 복구 씨디를 한번 돌려 보심이...
